But he hasn't done $600 in repairs...:naughty:foreverpsycotic said:get a waiver from a "trusted" shop that sais that the cost to repair emissions is too high, i think over 600 or so (at least in CT its like that)
xarewhyayen said:The only emissions problem i could imagine you would have is Nox emissions. Being im sure theres no EGR to reduce nox, the numbers will be a lil high. If the car isnt put under too much load, and its not running too close to stoich (14.7 AFR) it probably shouldnt produce alot of Nox(oxides of nitrogen produced when combustion reaches 2500 degrees fahrenheit)
koulee said:You assholes! Damn you for not living in California! Damn you all!
Oh, good luck getting a 1jz to pass in California. Almost any other state will pass. But not here.
lagged said:FWIW my 7m with no EGR had NOX levels well below the limit.
Wills7MGTE said:just make a set of 3 cats welded together and bolt them in for emissions tests. Or slip the guy some dough, or ummmmmmmmm steal a sticker
