CrazyInside;1912519 said:Wouldn't it be more fun to get the mk4 6 speed? Aren't those good for higher hp and still a manual?
that swap is close to 10k
gurley0916;1912522 said:that swap is close to 10k
flyjum;1912540 said:What transmission mount/engines mounts were you using?
stevenr816;1912557 said:Solid motor, poly tranny.
Hands down there absolutely no point in keeping a r154 at that power level. I haven't found anyone yet that hasn't broken any at 600+ wheel.
How would street driving suck ass? Freeway, eh but you can get 3.5X rear gears if your that concerned.
Does it suck power, technically. But the car is going to be so much faster that it doesn't matter. Endless pull in your power band, no lag between gears etc.
9s easily auto. Easy 10s with the 5sp setup now.IndigoMKII;1912666 said:Sounds like someone is chasing 10's. Do you already have a drivetrain collar and ATI damper etc etc?
A vendor online, it's not a bolt on occasion. You have to cut the bellhousing off the GM trans and machine it flat. Then the adapter bolts to the front of the pump.Sparky33;1912686 said:who sells the th350 to a340 adapter?
4500 rpm stall is what I would choose as well, cause it won't hit 4500 until under heavy load. Spray would be good if he's going to drag, just to get it up on stall faster.flyjum;1912774 said:What sort of RPM on the stall does he plan on running?
I would think a 4,500~ rpm stall is needed unless he is running spray to get the boost up on the brake.
No OD with 3.5X gears in a street car with a 4k+ rpm stall will cause some pretty bad heating issues
If his engine RPM is below the stall RPM on the freeway he will just be slipping converter
He could swap in NA gears in the rear to pull the RPM higher
Do they make lock up converters for this application?
suprakidd;1912886 said:id pay for a ride-a-long in that bitch, those friends of yours... super jelly LOL.
looks like way to much fun man![]()
Albert;1914698 said:naaaaaaaaaa
Do you know who I am?!
ill be CMM the 2nd, 3rd gear and counter shaft. get it cad modeled by Dustin, and Ill machine it out of 9130 alloy.
but for now ill thorw all the bearings in and all the MC parts and see how it hangs
