ebay acl pistons
oldfastpat
22
S.W. Michigan
The engine is at the machine shop. It had .020 pistons. They said it was OK at .020 but as long as I needed new pistons we went .040. I want to get the motor together than start trying to figure out what to do about engine management.It has a newer rebuilt 60-1 w 10 degree clip?? From what i've read,not to dependable. As always your help has been invaluable.
HENRY SIEMON
Dont be scare
Nov 13, 2006
San Juan, PR
:aigo: im running with this pistons 465 hp at the wheels at 30 pounds on vp with a to4e .81exaust.:evil2::evil2::evil2::evil2:
365 at 15 pounds at 89
425 at 25 pounds at 89
be awere with pistons rings gabs ,to close will broke..
Doward
4,245
Alachua, FL
IJ.;926197 said:
I'd like to see the bore first ;)
(Sadly I know what a closed end gap dead motor looks like)
Details? Fortunately, it's the ONLY time I've let my testosterone do the talking/tuning (long story short, I had it tuned WOT MAF system @ 7psi. Cranked up to 10psi without adding more fuel, since the MAF was pegged and I was unaware of this until the logs afterward. This is why I converted to speed density on that car, and won't run without a WB02 gauge anymore ;))
My rings broke the pistons (2 of them) between 1 and 2 - I figured that the rings overheated, and either a) closed the gap and *snap* or b) swelled in the ring land, and *crack*
Educate a youngster here ;)
Warm day long hill and not quite enough fuel system 30 psi 1 heat range too hot plugs and an IC that was about 100hp too small..... :(
Closed an end gap burnt a ground electrode off a plug and trashed a cylinder wall.
Very ugly so my new block got it's 2nd bore since I bought it.
danysbanshee
maine
Hey guys I appreciate all the replies to my thread. Iam not going to be building this 7mgte motor because...... I just aquired a gen 4 motor. 2jze twin tubo. with only 29000 on the odomotor :icon_bigg The motor has all the harness's and computer. A targa top car. Built auto. A stage 3 clutch if I go standard. Stainless exhaust. Hi performance stuts. Brand new in the box steering rack. All for 2200 bucks. Theres more too I just can't think of it all right now. So hopefully starting sunday iam going to drop that pig in my car.
