Early Vs Late 7M Blocks
Beefy_Heafy
Toyota Love
Nov 9, 2009
356
South East Qld
It must be somewhere around there. JDMMA70 Is yours an ma70 or ma71 model? Im going to assume ma70 due to ur name :p Mine is an 88 "turbo A" model. I don't know what month though. Its model number says its an ma70 and it has the old style block and 6m crank although it also has the different ma71 body panels. Its head casting has an "A" instead of a number
8,900
Jeff Lange;1578269 said:
ECU's changed at the same time as the crank, there was no weird crossover as far as I am aware.
Jeff
Do me a favor and look for different cam part numbers around the same time.
JDMMA70
2,550
Houston
ive seen a total of four late 88's so far that have the later style block so im wondering if they got them factory since it was so close to the 89 production date of Aug 88
JDMMA70
2,550
Houston
MA71 on the VIN
MA70 on the firewall
Turbo A's were made between Sept and October of 88.
Mine was made in June of 88. I have the newer style block, dunno what crank but most likely the 6M. The Turbo A should have the later style block with the 6M crank.
Beefy_Heafy
Toyota Love
Nov 9, 2009
356
South East Qld
Here is a piccy of my engine block and yes. It is the newer type block. My bad on that one :p
Jeff Lange
Administrator
4,926
Sunnyvale, CA
jefflange.ca
The blocks changed before the crank did.
All 7M-equipped Supras are MA70's, MA71 is not an official chassis code for ANY Supra.
In Japan, typically cars are given years based on production date, not "model year." Turbo A's were made at the same time as all other updated cars, they were not made earlier. Production started in 08/88 just like every other "89."
Cranks & ECU changed in 08/89 production for "1990" model year.
Jeff
tsupranami
Drain Bamaged
Mar 11, 2006
134
Eastern WA
Hey IJ,
Do you have any photos of the front of the new "heavy" block?
Did the new block come with the small convex brass core plug installed (the one behind the aluminum inner front timing cover?)
Thanks
tsupranami;1581353 said:
Hey IJ,
Thanks
No probs, Stock is a Steel plug in the factory blocks.
8,900
What about the GE block? I know the original GTE came from the GE block design for the 87, it is obvious. Did the GE get the updated block ever?
8,900
IJ.;1598469 said:
GE's were updated before the GTE's Nick.
That makes the Cressida more viable in the "maybe if I get around to it project" category. We have quite a few 89-92's in the US with 200k on the clock.
Jeff Lange
Administrator
4,926
Sunnyvale, CA
jefflange.ca
GE's and GTE's started production at the same time. Also like IJ said, they were updated as well to the newer design.
Jeff
Mikael_7m
Built 7M
Apr 26, 2009
283
Australia
hey guys I purchased a 7mgte and from looking at this thread IJ made, it seems I have a late block (more ribs) but a 6m crank. This motor doesnt look like it's been pulled apart before...?
Confused :\
gats
Rebuilding... Slowly!
Mar 3, 2009
182
Sydney, NSW
Confused :\
Same boat as me mate, my car is an 04/89 Aus-spec GTE with a late block & 6M crank... More of the weird '89 model obscurities I guess :confused:
