e-manage Ultimate...Yay or nay?
Adjuster
You can datalog the WB output, and assign values to that output that mimic's the WB readout. (Nice info to have on your Eman screen when your tuning, you can watch what the AF's are doing across the RPM/Pull.)
The E-01 and GEM does not control a WB, or do any automatic tuning with this data. YOU CAN ONLY DATA LOG IT, and then only if you program the scale with correct info.
tkvtec
12
CT
I got the Emanage Ultimate running on my 7M tonight. Just with the basic connections, haven't gotten so far as the injectors/ignition yet, but I didn't have the time yet.
And yes, I was mistaken, I was confusing the EMAN BLUE and E-01 combo and all I read about that, with the EMU stuff I was reading at the same time.
I do have a question for those running the EMAN Blue on the 7M.
Do I need to set this up to use the 12v Analog for RPM or 5v Digital? Setup with the 5V digital my RPM's aren't reading any higher than about 2000rpm, and my Turbo Timer has the same issue with reading the RPM's really low. I know HKS sells a product for the turbo timer to convert the 12v analog to 5v digital so as to get an accurate reading.
bowsercake
828
Irvine, Ca
Sorry to bump this thread but I was wondering if anyone else was running the Emanage Ultimate and if they were getting it tuned well.
