Dyno my baby today :)
T701jz
3M ENGINEER - R.&.D
Jul 23, 2005
657
Santa Clarita Ca.
My stock set up back in the days...
JZA70 2.5L with 3" full exhaust, K&N intake, Mines ecu, and 2.5 intercooler pipes = 312whp (@13psi/7Krpm)...Just another comparison
Greek
513
Ohio
Nick M;1815360 said:
Off the top of my head, 210-220. Horsepower is calculated. It requires a certain amount to cover distance and to achieve certain speed in time. Plug in your numbers. A 5 speed car will hit 100 easier than the A340 for obvious reasons.
http://www.corral.net/tech/brakehp.html
The DSM guys has an online calculator some time back. Same thing.
WEIGHT 3600 pounds
TRAP SPEED 100.58 mph
E/T 14.06 seconds
Total Horsepower 292 bhp
Horsepower Used 255
I was running 10 psi, stock everything but exhaust and radiator. I'm assuming that the 292 hp is at the crank, and the 255 is at the wheels?
8,898
Greek;1815395 said:
WEIGHT 3600 pounds
E/T 14.06 seconds
Horsepower Used 255
You sure it is 3600 lbs with a driver and fuel? Base weight with a hard top and R154 is about 3550. It took 292 hp to push 3600 lbs up to 100 in a 1/4 mile. That is the energy spent, and isn't effected by gears. The ET, which was horsepower used can be changed by the gears. But speed doesn't usually change with a diff change, only ET. Some call it rwhp, but that isn't accurate. It really is speed method and ET method.
Speaking of calculating HP, at dragtimes.com, they have a link to the corrected ET and mph. It is hooked to a database with elevation and weather for the day you ran.
8,898
Turbo Habanero;1815366 said:
Okay so after redoing the numbers a little and playing with it i used my last time at the track
98.90mph trap speed
14.368 e/t time
It was my car 89 Targa full interior/full engine parts AC cruise ect.
50lbs of tools
150lbs of me
125lbs of my girl in the car
so i entered 4000lbs as weight.
Mr Watt timed how long a horse took to walk an arm in a circle (he wasn't the only one). Force in a rotating motion is torque. How fast work is being done is horsepower. Literally. And the two are very intertwined. That calculator is applying those known work and force rates to what you did in your car. It took 306 hp to move your 4000 lbs 1/4 mile in 14.36 seconds. The best ET is just showing what a crappy driver and how heavy your car is. If you had a 3100 lb Fox body, you could run deep in the 13's with 306 hp.
Turbo Habanero
4,229
Tucson,AZ
So what its saying is i only have 306 Crank horse power...
my mods on this day
Driftmotion intercooler kit 2.5 inch piping Hks ssqv3
3inch straight pipe stock turbo elbow
ct26 60-1 @ 12spike dropping to 10
3inch intake filter
lexus AFM
evo 8 560cc injectors
Stock ecu
Tires where dry rotted and super bald 225/40/R18's (no name brand)
Bkr7e gapped at .28
Does this seem right ??... or is there something really wrong with my car ?
Greek
513
Ohio
Whoops, then no I definitely got the weight wrong. With spare, me, and fuel I'd guess 3900-4000. Which the calculator says 316;277 respectively for 3900 pounds, and 324;284 for 4000. That seems like an awful lot for a stock motor on upped boost.
Turbo Habanero
4,229
Tucson,AZ
Lol you have mote power then me sad face :(
8,898
Greek;1815736 said:
I don't think it's correct though.
The only thing not correct would be the numbers put into the formula. Why would think the car should make more power? 300 hp is quite a bit on a small engine with a street head.
Greek
513
Ohio
I'm thinking it's too much, not the other way around.
mkiii222
Troy, MI
I'm just glad a MKIII had the balls to get up on Titan's dynojet this year. I was there last year and it was MKIV after MKIV with 1 DSM thrown in for giggles (he made 4xx after Darin laid down over 1100 in his yellow MKIV).
I always thought that combo produced a little more as well. Thought my stock CT, 3" turbo back, intake, and boost controller was good for 275 at the wheels. Oh wells, won't be stock fuel for much longer and then it's time to figure out how to break 12psi (MAFTPro vs MegaSquirt).
Turbo Habanero
4,229
Tucson,AZ
Don't you think traction has Alittle to do with this calculator.
Just because if I'm spinning tires through the 60ft then my mph is going to be lower at the end of the track...
Maybe that's why it shows Greek at more hp on a stock ct then me on a 60-1.....
IndigoMKII
2,181
Madison, Virginia
Relax, you're putting down more power than you think.
laxboy36
282
Chesapeake, Virginia
yeah, I was going to put it in the car show as just clean car, and then it was 10$ more for dyno, i said fuck it, i want numbers and i was shocked so. and i put up the same number as a 5.0 foxbody mustang
te72
Classifieds Moderator
6,611
7
WHYoming
Actually, the more traction you have, the ET tends to be lower, but the MPH tends to be higher, at least from what I've seen over the years. Seems backwards for sure, but look at the cars that can't hook up for crap off the line, they cross anywhere from a few to a lot higher MPH than they should be for the ET.
Turbo Habanero
4,229
Tucson,AZ
Maybe my motor is about to take a Crap lol
Unless that stock elbow was chocking the car out that much but I don't really feel I big difference with the 3inch elbow
