Great!! Now you're joining the team!!!! Have to go, don't have time to read the thread now, but I'll read the whole thing later for sure.
high psi 1jz said:You don't HAVE to machine the block unless its serverly warped. You can put on a thicker hg like a 2.0mm.
high psi 1jz said:Your gonna have to do the head gasket eventually, kinda like the saying: "Measure twice, cut once", well: "1 Metal HG, no BHG''....haha... no seriously.
high psi 1jz said:See this is where it gets weird, you wanna do (from what I see) a kinda mild buildup but when you get talking into upgrading the head (cams, porting, valves, springs, retainers) I'm not sure what you overall goals are with the car, with some of those mods I listed there, you could be one of the high 57trims out there.
high psi 1jz said:The Supra blows head gaskets BECAUSE of Toyota, undertourqued head bolts, shitty gasket, and weak studs. I suggest a quality METAL head gasket from Cometic, HKS, Greddy etc.... also ARP Head Studs and tourque the studs to the correct specs.
high psi 1jz said:^ Metal Head Gasket? If your doing doing the head gasket anyway why not throw on a good quality one? Its a direct replacement.... no need to take the motor out.
Sawbladz said:You should pull the motor to do a MHG. You need to make sure that the block has no warps and that you have the correct RA for the headgasket to seal properly.
Sawbladz said:http://www.supramania.com/forums/showthread.php?t=29335
I think I'm with JDub on this. This is an interesting read and should be read before making this decision.
Specifically...
"My contention has always been: You want to have a MHG seal correctly? The RA spec (or smoother) for the specific MHG must be met for both the block and head, the machine work must be precisely flat for both the block and head, and the proper torque spec for the fastener used must be applied in the TRSM sequence. Attention to detail on these is what ensures a proper seal." quote from jdub
dugums said:My power goals are modest. Furthermore, I plan on tuning, so it should be running rather well.
We'll see if there are any other new opinions on this. Otherwise, I think I am going to stick to my plan.
New question:
Is there any additional work I can have the machinist do to achieve better flow/power/anything. i.e. anything to the intake or exhaust manifold, valve job, etc.
starscream5000 said:Heh, I should have just copied and pasted that post.
Sawbladz said:This is what I do when I'm bored...I link people to the stuff they should read and let them deceide for themselves.
I'm basically in the same boat he is. I'm about to rip my car apart for the first time and build my own motor. I've been reading as much as I can find for the past month or so. In a short while I will be posting my own build thread in which I can ask my final questions and get ready to spend money. In the meantime...others can benefit from my ability to use the search![]()
