S
SLOW7M said:Im trying to do a tripple pump set up on my car
Do you know where you can get the tripple pump hanger for the mk4?
annoyingrob said:If you need 3 walbros, maybe you should think about getting some higher quality/flow pumps instead![]()
Justin727 said:a few guys have not used the sump and tapped the bottom of the tank.
SMP142 said:i am planning on running one aeromotive A1000 with -10 feed. using a sump setup of course.
flubyux2 said:you guys with bottom-feed pickups for your external pumps, do you use the stock fuel return line or what?
the only thing im afraid of is water collecting at the bottom of the tank if the car sits for an extended period of time. what would you do about that? turn the pump on and let it pump out any water, cycle it and hope it dumps back into the tank and breaks up before trying to crank the motor?
anyone installed a water/fuel separator from a diesel? my truck has one of these, maybe that would be useful for bottom-feed setups?
SLOW7M said:What are you using for a fuel rail?
