Driftmotion 1JZ Oil Pressure Guage Adaptor
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
Ok, I know these things are selling like hotcakes. I have one, but I have no clue where anything on the 1J is located. Can someone take a picture for me so I can see where exactly this little adaptor is supposed to go? Aaron says it's mounted next to the AC compressor on the block, and that I need to hook the wire that was for the 1jz oil pressure switch to the 7m sender and you are done. Can someone take a picture of this as well if possible? I need the pic before the 18th (the next time I'll see my car and work on it). I'd like to get this little trick piece installed finally since it's collecting dust in my glove compartment. Thanks all.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
Yup, it's the one marked "2". I had to take my compressor off to get to it. It was a good time to switch the plates on the compressor since I forgot to do it when the engine was out.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
yup just screw in the the adapter line and then the 7m OP sending unit on the end of the line then plug in the wire and BINGO yur golden
did this on a buddy's 1J and will be doing it on mine soon LOL
ForcedInduction
125
Chicopee, MA
Didnt mean to bring this back up, but I just did this and my gauge still doesn't work.
I took out the pressure sender that was in the block and plugged my driftmotion line into the hole with the 7M? sender(stubby and short) and plugged the connector on it, my gauge still reads 0. What did I do wrong?
