Driftmotion 1JZ 60-1 Single Turbo kits installed pics
Spaniard
524
La pearla PR
honestabe;1379392 said:
I need 1J pics with the DM 60-1 turbo kit installed. Specifically of how the oil lines are attached to both ends. :1zhelp:
Adam
Why Adam? Problems? Do I need to go up there and do the install for you? :nono: lol.
Panchira!
Cressida+1jz+GKT550= :)
Jan 3, 2008
50
black hole
well i dont have pics but i can tell you how to mount the oil lines. first off youll need to mount the 90* hose extension onto the turbo first. loosen both the exhaust and compressor housings so you can clock it correctly (not extreemly loose just a hair loose so you can rotate it). when its in (90* hose) it will be perfectly between the compressor housing and exhaust mani then tighten (must mock up the turbo at this point). the oil feed line will go from the front port on the block looped as close to the fender well as possible and install the oil feed fitting then the oil line. clock the center section to get it level as possible then tighten 1 or 2 of the comp & exh housing bolts pull turbo off tighten everything then reinstall turbo connect drain upper fitting first to the turbo then to the oil pan. your done.
pnutcar
1jz Asshole :)
Jan 25, 2006
299
St. Louis, MO
Did you get it figured out from those pics Adam? Its not hard, just a few lil pita things that you have to do with any turbo.
Flateric
946
Calgary, Alberta, Canada
Hey man, how about a few pics of the routing now that you got it figured?
I'm in the same boat you were ealier and as you know a pic is worth a thousand words.
:icon_bigg
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
honestabe;1380442 said:
Got it all figured out thanks to Todd and Trevor. Big thanks to Quin for figuring out what car uses the oxygen sensor I need since the stock o2 sensor is the bolt in type and I need the screw in type (93 Ford Mustang 5.0).
i think we used the 98 toy supra O2 sensor...
