doom's build thread
doom26464
Research...research
Saskatoon SK, Canada
UPDATE:
car at first wouldn't start and wasn't getting fuel. The stock fuel pressure regulator needed to be fixed. now Its getting fuel and spark but won't stay running it just backfires a whole lot. Timing is off or something isn't firing right. Belive its the CPS will soon find out......
doom26464
Research...research
ok cps was the problem IT runs now. trying to set timing but coolant started leaking out by the water pump. The gasket must be faulty. Going to replace it. Sooooooo close to running im soo excited to take it for a drive. I just over stressed and worried I messed something else up as this is my first build and learning experince:aigo:
NewWestSupras
SoupLvr
Mar 1, 2006
611
White Rock
Congratulations, lets hope this build goes flawlessly from now on. A just reward for all the hard work. You did a nice job there. Gl on the last few details!
doom26464
Research...research
IT runs!! took it out today though it was kind of cold. idels perfectly. Turbo is amazing pulls very very strong though i only took it up to 4k but it feels like it could defently keep going. IT only at 7 psi right now but i would love to see what it could do at 20:). however there are a few bugs that need to be fixed. check engine light is on and getting code 52 wich is knock sensor so it might need to be replaced or rewired. the boost when it comes on also seems to hesitate or something not sure yet what it is but looking into it.also temp gauge isn't working not sure if its the wiring or the sendor but i have a spare sendor so i will try installing it. Its just so damn cold out to do anything on the car so I will have to wait till the weekend to drag it too the shop and work on it.
but other then that its a blast to drive and i miss the deep sound of the 7m and the noise of the turbo :)
doom26464
Research...research
IJ.;943389 said:
4>5 heat cycles
1 heat cycle = stone cold to operating temp
DON'T get hard on boost until done.....
woops i already boosted it a few times today. though i never took it over 4k. wish i would have read this first. I never though that it would need a re torque though. What would happen if i didn't re torque it? do the arp bolts back themselves out and the hg will blow?
EDIT also i don't have to take the cams off to do a retorque correct? just the valve covers.....sorry its been awhile and can't remeber
Never used their bolts but I've seen studs relax on EVERY 7M build I've done doesn't seem to make a difference if new or used.
I retorque every time now.
Dunno fingers crossed you "should" be ok just get it done asap.
(there are quite a few posts on the correct procedure)
Cams stay in place but you might need to turn the motor a touch to get the socket on.
doom26464
Research...research
all right i get it done this weekend its only been threw one heat cycle wich is today
doom26464
Research...research
IJ.;943470 said:
Take it out for a gentle spin around a big block each day between now and then just get it up to operating temp each day.
i take it too work and back wich is a big block away so that should do the trick. not having a temp gauge scares me though need to fix that this weekennd.
doom26464
Research...research
All right so car runs good and smooth but there is some isssuess that need to be done
1.bov won't vent properly-FIXED!
2.brake light doesn't work-FIXED!(actually it fixed it self somehow)
3.retorque headgasket
4.fix front right signal light
5.get temp gauge to work
6.speedometer stopped working(it worked fine but now it just stopped today)
7.replace a cracked coolant hose
8.check engine light on. CODE 52 wich is a knock sensor code
