dok33 said:Thanks for the compliments, I'm looking forward to getting it done.
MDC-I have some 680cc injectors I'll be using with the Lex, E85 requires ~30% more fuel so with a little more base pressure I should be a-ok. Quite a few people run Walbros with E85 (check NASOIC etc.) with no issues, I've been running one in my turboed Escort for a while with no problems. If you look at pg1 of this thread I posted some info about research that they're doing on E85 with their pumps.
As far as AFR goes, lamba is the same (and thus o2 sensor voltage) for a stoich. burn no matter what fuel you're using. Air/fuel ratios are scaled differently between gas and E85 (9.76 vs 14.7 for stoich), but you can leave the scale alone and tune for gas AFRs with no issues.
I'm running 30% larger injectors on my Escort and it runs great on E85 with no tuning. The ECU adjusts the same based on O2 sensor readings no matter what fuel I run, my afr logs from the wideband look the same whether I have the larger injectors and E85 in the tank or stockers and gas.
mobes said:Hey, this is Jon from the meet (I had the orange 350z).
That looks like a nice clean car to start from. Just needs a buff and wax
I used the same downpipe for my 1JZ. I put a flex section in mine and swapped the bottom flange for a V-band though. Let me know if you need a hand or any random little parts (big stuff gets eBay'd but I have a whole slew of bolts, clamps, etc).
hottscennessey said:Good choice![]()
dok33 said:You sir are my inspiration, I've read your build thread quite a few times :naughty:
