well , i should have started this thread a few weeks ago, but that was all tear down!, not any of the fun stuff where going to want to see.
now im rebuilding my own engine at my college shop,
the reason for the rebuild was i was blowing compression into the coolant system , causing to run hot after boostin, and making the car non-reliable.
sadily i knew i needed to the block surfaced, so a basica rebuild was due. i have power goals of access of 500 horse, and i atleast want to get started in the right direction.
so far this is the list of new items.
-titain 2.mm mhg
-all crank & rod bearings through toyota
-toyota oil pump drive bearings
-toyota soft/freeze plugs
-toyota ring set
-thrust washers-toyota
-arp rod bolts
-arp main stud kit
i have had my motor balenced, crank-rods-pistons- flex plate-& harmonic balencer
the block has been decked .009" and a 25ra finish, aswell as being hot tanked.
well here's a few pics so you can get a picture of where im at..
btw, sorry theire cell phone pics at the moment..
top of the block lubed with oil to aid in rust prevention.
main journals lubed up just like the deck, btw remove the oil before installation of the new bearings. do remember to add a assembaly lube to the bearing surface though!
a few pics of the arp main studs going in. and yes i check with the oil pump to make sure i had the correct bolts where needed.
and no this isn't chevy orange, or salmon pink it's a chysler red. looks red-orange but with shop lights has a pink salmon look to her..
any ways, more to come!
-titain 2.mm mhg
-toyota ring set
-arp rod bolts
-arp main stud kit
