dodge neon
willfish
been here since 2003
Apr 23, 2005
648
Pittsburgh, Pa.
seriously , just how fast is that dam sr-4 ... or what ever it is called. I have heard around here that its really fast and that it beats a rustang. All I see is the really is all the younger kids driving them acting all hard an shit......
My 90 T isint stock and all I really have is bolt ons, but it's really pissing me off people telling me it'll run me.....
Will
empera
Authorized Vendor
Philly.
those cars are supposably fast but they're still shitty neons...so fuck them POS cars
MKIIINA
Destroyer of Turbos
Plano, TX
yea the staged ones can be a bit of a handful but if you are bpu you should be fine. from a dig the older ones are easy to beat unless they have a really good driver as there was no LSD to start out with (now comes w/ a quaife iirc) and w/ the small turbos that spool at idle (ok maybe little higher than idle ;) ) its hard to launch. take it to the highway and the problem becomes more evident as they run outta breath it seems near the 3/4 of each gear.
that said give it the proper "stages" and a driver w/ some experience and it could be a nice battle
edit: as for waht to look for iunno. i know the stage 1 or 2 is larger injectors, ecu remap, more boost and something else...... damn
plus side is that their exhaust is a problem. when we open up the exhaust on our cars we lose spool time and also gain a pound or 2 of boost. with the srt4 when they do exhaust the ecu reads it like out of control boosting and cuts back harshly to keep the boost from going much higher :)
P
PunaMKlll
Guest
its a fucking neon engine with a turbo@12psi stock! its a POS, too much power on a FWD. The only decint 1 ive seen was a CF body with sum little mods, but even that was pathetic for how much it cost.
becauseican
Vancouver
www.bicperformance.com
Watch out for those things they can be made fast with little money. I have personally seen on with 3" exhaust, a few more pounds of boost and slicks do very low 13s. Last weekend a friend of mine dynoed his srt4 and made 440 whp and about 450 TQ!!!!!!!!!, with a t3/t4 and other minor mods. Later that day he made a 12.7 pass at about 120 and another that was a bit quicker but I dont know the number off hand, while spinning the tires past the 60' mark.
siman
Lifetime Ban
Murfreesboro, TN
So many of you guys dissing and pissing on the SRT-4.....
About how many of you have actually DRIVEN one? I have...I hated them at first....but after a couple of "fun" rides...they are NOT to be taken lightly, and the quality is there as well!
The shifter is far superb to the se-r spec-v or RSX-S, and boosing 5lbs at 1500 rpms is very impressive as well.
much less they LOVE backroads.
I suggest you guys test drive one....then come back.
-Jonathan Mann
Orion ZyGarian
Jeff Lange wannabe
Apr 2, 2005
1,490
Sarasota, FLorida
www.suprastore.com
No kidding...lots of people hating here. For one, its not a stock Neon engine....or a Neon engine at all really IIRC. I agree it'd be better off RWD, but shit happens. They put it in a Neon body to compete with the 4 door fast car thing now...sorta to make it sleeperish in a way. You guys hate too much...really, lighten up!
PynkEye
I heard they ran high 14s on the quarter...stock.
Best performance for the buck apprenlty.
Ya they are shit neon..just changed names...but the srt-4 is...another story in my opinion (more respect for it)
7MGTEJoe
Salinas, CA
I've seen one run low 14's @ 100.XX mph stock. I wouldn't buy one but it's the fastest late model for your money right now.
It sounds like there's some misinformation floating around about that engine. It's not a stock neon engine with a turbo bolted on, it's an entirely different block. It has piston cooling oil squirters, revised water jackets for improved cooling, additional oil galleys, a high volume oil pump, cracked cap forged rods, low compression pistons with a shorter skirt and a hard-anodized top ring land, a hardened crankshaft and inconel exhaust valves.
Daimler-Chrysler actually put some effort into making this a solid engine. We'll see how it ages but it looks like a good design.
