mk3-4-me;1636050 said:
dude i know what the hell is under a car... lol
ya the drive shaft turns when i spin the wheels, obviously it would if its connected. The diff works fine.
and ya the shift linkage is connected and moves back and forth fine.
I am sure you are frustrated, just a reminder that having any type of attitude (regardless of what is said to you) is not beneficial in getting help.
The description below is not directly related to your real issue, but your above statement, I am not certain that you have a complete understanding of a LSD differential, therefore is perhaps getting in your way of narrowing down issues with your transmission.
See quote below from internet resource - particularly the sentence that is in
Bold Italics This may help you understand why your answer is either not complete or inaccurate in regards to whether your turning your rear wheels is actually turning the tranny or are the just spinning about the crown wheel gear ie turning opposite directions while the drive shaft remains in locked (park) position.
___________________
The following description of a differential applies to a "traditional" rear-wheel-drive car or truck with an "open" or limited slip differential:
Torque is supplied from the engine, via the transmission, to a drive shaft (British term: 'propeller shaft', commonly and informally abbreviated to 'prop-shaft'), which runs to the final drive unit that contains the differential. A spiral bevel pinion gear takes its drive from the end of the propeller shaft, and is encased within the housing of the final drive unit. This meshes with the large spiral bevel ring gear, known as the crown wheel. The crown wheel and pinion may mesh in hypoid orientation, not shown. The crown wheel gear is attached to the differential carrier or cage, which contains the 'sun' and 'planet' wheels or gears, which are a cluster of four opposed bevel gears in perpendicular plane, so each bevel gear meshes with two neighbours, and rotates counter to the third, that it faces and does not mesh with. The two sun wheel gears are aligned on the same axis as the crown wheel gear, and drive the axle half shafts connected to the vehicle's driven wheels. The other two planet gears are aligned on a perpendicular axis which changes orientation with the ring gear's rotation. In the two figures shown above, only one planet gear (green) is illustrated, however, most automotive applications contain two opposing planet gears. Other differential designs employ different numbers of planet gears, depending on durability requirements. As the differential carrier rotates, the changing axis orientation of the planet gears imparts the motion of the ring gear to the motion of the sun gears by pushing on them rather than turning against them (that is, the same teeth stay in the same mesh or contact position), but because the planet gears are not restricted from turning against each other, within that motion, the sun gears can counter-rotate relative to the ring gear and to each other under the same force (in which case the same teeth do not stay in contact).
Thus, for example, if the car is making a turn to the right, the main crown wheel may make 10 full rotations. During that time, the left wheel will make more rotations because it has further to travel, and the right wheel will make fewer rotations as it has less distance to travel. The sun gears (which drive the axle half-shafts) will rotate in opposite directions relative to the ring gear by, say, 2 full turns each (4 full turns relative to each other), resulting in the left wheel making 12 rotations, and the right wheel making 8 rotations.
The rotation of the crown wheel gear is always the average of the rotations of the side sun gears. This is why, if the driven roadwheels are lifted clear of the ground with the engine off, and the drive shaft is held (say leaving the transmission 'in gear', preventing the ring gear from turning inside the differential), manually rotating one driven roadwheel causes the opposite roadwheel to rotate in the opposite direction by the same amount.
When the vehicle is traveling in a straight line, there will be no differential movement of the planetary system of gears other than the minute movements necessary to compensate for slight differences in wheel diameter, undulations in the road (which make for a longer or shorter wheel path), etc.
---------- Post added at 10:24 PM ---------- Previous post was at 10:20 PM ----------
mk3-4-me;1636078 said:
theres no special way i have to put the TC on is there? like if i have to line something up?
Not exactly directly speaking of the TC, but did you verify the concern in this statement >>>
IJ.;1631272 said:
Only other thing I can think of is a broken pump in the front of the Trans, this happens when you don't align all 3 sets of splines before bolting the Trans to the Engine...
