best way from my experience is to have the throttle body off and lay it down run the part that goes through the intake runners and pull it down and then go over the valve covers. Just take a look at all the clips on the sensors if the wire looks old bridal or like is only holding on by a thread then de pin it and solder new wire and pin. I would look at the 4 wires that go into the cps cam position sensor from the harness side my were fucked when I did my rebuild the other day and car would not start. Also check the coil packs on the harness side they get bridal too. It looks just the the cps clip 4 wire clip.
