DECELERATION - Clutch ENGAGED or NOT?
iwannadie
981
gilbert, az
jetjock;1539684 said:
Great. Yet another thread where we see people who think they know how to drive versus those that really do...
Can I ask how you would handle a particular situation? Lets say you are coming to an intersection and the light turns red leaving you plenty of time to stop. Will you clutch in, shift to N and clutch out while applying the brake coming to a stop? Will you downshift and speed/gear match while braking until you are at a stop? Maybe you gear/speed match but keep the clutch pedal pressed the entire time while braking to a stop?
I never feel comfortable shifting to N in case I need to accelerate again. Even in the above example I would not feel right being in N while rolling. I'm just wondering if I'm paranoid or is the correct thing to do would be shift in N and not be in gear coming to a stop.
KMinAF
Old Man
Sep 15, 2006
291
American Fork, UT
Brake pads are cheaper than clutches (and thrust bearings if you run a stage 3.) I just push the shift lever into neutral when coming to a stop, "heel toe" when down shifting through a corner and never hold the clutch in while waiting at a stop or rest my foot on the pedal while driving.
iwannadie
981
gilbert, az
I had a friend who burned through two clutches on his SUV before a mechanic finally asked if he rested his foot on the pedal. My friend said he never thought that slight bit of pressure made a difference but it did.
A. Jay
Search.
Jun 3, 2009
671
Bay Area, CA
Poodles;1539677 said:
I remember being taught in driver's ed. here that's it's illegal to coast in neutral or with the clutch in.
Not that they could possibly know you were doing it, but it all depends on the type of stop I'm doing.
Same in Cali, they tell you that you'll get points off in the behind the wheel test if you don't leave it in gear.
supramk3speed;1539741 said:
I use the idle and downshifts depending on what i feel like. I usually downshift if im slowing down to make a turn but i generally put it in nuetral at stop lights because i don't want to sit there holding in the clutch. That would just be a pain.
And it would wear out the throw bearing...
GrimJack;1539958 said:
I'll say this... I don't like putting more wear than necessary on the throw bearing in the clutch assembly, so the times that my clutch is in are extremely limited.
...which I also avoid doing.
I don't do it, but I also didn't know that that could happen, good to know anyways.
If I'm in first I'll put it in neutral and let go of the pedal, unless I'm inline for a stop sign, which in that case I'll leave it in first. If I'm in second it depends on if I have enough room to let go of the trottle slow enough to keep the car from jerking back and forth.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
....And easier to replace.
Koenigturbo
1,337
Oxnard CA
I had my tranny rebuilt, the guy asked me if I down shift to help stop. I said yes, he said, yeah, I can tell, your second gear is mushroomed from down shifting.
I'm in neutral when I'm at a stop.
supramk3speed
305
Texas
If i was going to a road course of course i would down shift to slow down. I think its better as a measuring tool as well, you can judge corner distance better by doing downshifts. As for neutral slow downs, its just a quick kick to the clutch and a move of the gearstick to put it back in gear, not hard. If you don't have enough time to do that you probably didn't have enough time to react anyways.
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Dirgle;1539689 said:
Besides, the engine cuts fuel on decel so I can get a few extra miles out of the tank.
Does the engine cut fuel completely on decel? I've never heard about this.
crisp;1539833 said:
So... I'm actually quite pleased that you chimed in! Hopefully, you have some words of wisdom to counter those in the "THINK" camp and better arm those of us who lack the resource and/or experience to know better by our own accord.:1zhelp: -crisp
It seems he only bothers to chime in to imply that he knows while others do not...
I've heard some BS over the years but that's up there.....
Not sure on the stock strategy but most cut down to xx road speed yy rpm, I found a full cut in my car with the thin JE ring pack caused excessive Oil consumption so set it up to have a lean map on trailing throttle, much the same gains in economy but enough fuel injected to maintain cylinder pressure.
thedave925
Since 9/16/05
Nov 9, 2005
626
East Bay, Cali
It seems he only bothers to chime in to imply that he knows while others do not... Must be an ego thing.
Some people have an abrasive sense of humor.
What if he's stoking the fire of debate, or just a pessimist wondering what new fad will come of this discussion?
Ask a smart question and you might get a worthwhile answer ;)
Dirgle
Conjurer of Boost
Pauma Valley, CA
I don't remember for sure on the 7M but on my 2JZ it cuts fuel on decel if the throttle is closed and the engine is above 1500 rpm. Once the RPM's drop below 1500 you can hear the fuel kick back on by a sudden change in the exhaust note and the wideband coming back online.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Same kind of thing on the 7M, although it might be running a small amount of fuel... not enough to read better than 20+ AFR on the wideband, though.
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
Yep this is spot on, the car pulls fuel when decelerating above 1500 rpm. On my car Fuel does not come back on line until 1200 rpm, but if you let off throttle between 1200 and 1500 it will not pull fuel and the exhaust will make a popping/gurgling noise while coasting down when this is happening.
I too am somebody who downshifts at every stop and rev matches, and normally I will heel toe as well (brake and rev match together). Doing it all the time has made me quite good and made it second nature when out on a real race track.
Shift neutral and stop. Down shift to stop fast. Rev match when necessary. Double clutch sometimes.
Most autos up shift and then down shift through all the gears at low rpms until your almost stopped and then it shifts into first.
Between constantly shifting at low rpms and idling for 10-15 sec coming to a light there really is not that much to be saved in gas imo.
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
If the car is moving and I'm not shifting gears, the clutch is engaged and engine connected. To slow down I heel-toe through the gears as I brake to keep the engine under control, coming to a stop in 2nd gear. Even if I was only doing 30mph.
The exception is an emergency stop, in which case I dive the brakes and follow with the clutch a moment later so the engine doesn't stall, especially if I was cruising in 5th gear. This is important because you may require the presence of mind to make it into 1st and launch hard immediately after coming to a stop... or get run over by a semi for example. Having to start the engine AND make it into 1st gear and get out of the way is a recipie for disaster.
Either way, if the car is moving forward faster than walking speed (regardless of acceleration or deceleration), the clutch should be fully engaged at all times, as far as I know and have been taught.
airhead04
1,489
Lima, Ohio, United States
Well, this is my first manual car. So Im not with all the lingo...what is heel toe and what do you mean by rev matching? Sorry Im a noob on that.
I downshift when coming to a light, and if I have to stop kind of quick I downshift and use the brake. I was told to learn how to downshift because it helps you ALOT in the snow. I dont know how much truth there is in that though. So help?? please.
