I had a problem with a chipped deck when I was putting some ARP head bolts in a block that was sitting in a junked car for good 2 years. The guy who I got the car from had a BHG and he took the head off and left it in the hatch. The bare block had made home to All sorts of Wasps and other animals 0ver a period of time. The Machine shop cleaned it as best as they could.
I installed the ARP head bolts into the block without the head first to make sure the threads were clean. THe first few went on Ok but then the rest started to get tight.
So I took em all out and rechased the threads, Turns out the holes had mud or sand inside it from what ever the hell had made a home in it. and the deck chipped. Insted of screwing around with it more, I just tossed that block and started on a cleaner one.
Now, On my cressida block, I was putting my blitz oil pressure gauge so I was trying to take the old oil sending unit off so I can put a T-Fitting in. Well the damn sending unit broke and the threads got left inside the block..
I broke out the ol extractor and put it in the hole and the goddamn extractor broke inside the hole. So I took my dremel and drilled a hole just a little bigger so I can put a bigger extractor in it without the other extractor falling into the block.... Son OF A Bitch, That bigger extractor broke.
I put some JB Weld on the Broken bastard, let it sit over night.
Next morning I took the car to a friend of mine who's got a welding shop.
Showed him the mess. Oil was leaking out of that hole slowly.
He used a screw driver/hammer and broke the JB Weld off of it and then broke out the Torch and some Brass solder. and filled the rest of the Brass fitting hole with Brass. So I have no more oil leaks. Its holding pretty good for now.
As for the oil sending unit and the T-Fitting. I used the hole closer to the front plate right behind the power steering pump and that took care of this problem.
CAUTION:- IF YOU DO ANY WELDING ON THE BLOCK WITH OIL STILL IN IT, MAKE SURE YOU DRAIN THE OIL, POP THE OIL CAP AND DIPSTICK. THE HEAT GENERATED BY THE TORCH CAN BUILD ENOUGH PRESSURE TO POP YOUR VALVE COVEFRS RIGHT OFF THE HEAD
