This is my first diy so give me some slack.. Im going to install it on a w58 but i think its the same concept with an r154 .
Parts needed are: Marlin crawler shift lever ball seat and bushing.
Oem shift lever gasket:
First step:
Second step:
Third step:
Fourth step:
Fifth step: Clean the area of any type of old rubber.
Sixth step: Install the MC bushing seat into position like the gif below. It doesn't go in that easy so i heated the bushing for 30 seconds and it went in easier.
Seventh step: Remove old bushing from the ball end, mine didn't have any on it. Then take your new nylon bushing and tap it on with a rubber mallet.
Eighth step: Apply some moly grease on to the seat and nylon bushing, then install the gasket with the shift lever and the 4 10mm bolts.
Ninth step: Install the rubber boot with the 4 10mm bolts and your center console.
Tenth step: Go for a drive and enjoy. The difference is incredible. Gears go in more precise, barely no play when is in gear and much stiffer. 10X better than before and the best 20 buks ever spent(no lie).
First step:
Second step:
Third step:
Fourth step:
