If you can find any pinouts, there is one wire that should be labled as a speed or speedo wire. These cars dont use an electronic speedo (other than the digidash cars). cut that wire, if it doesnt remove the cut then splice it back together.
So that's why my check engine light comes on... :naughty:foreverpsycotic;1021686 said:I have this done, it is is the pink wire in pin 8 of Ig1. The CEL only comes on over 110, it isn't on all the time.
Yeah, cutting the wire from the speedometer will eliminate the speed cut.
If it starts throwing a CEL, I know of an easy wiring fix to that too![]()
Marotta1;1022683 said:What is the easy wiring fix for the cel if cutting the wire?
SupraClaou;1024064 said:Boys and Girls...get the Trust Greddy speed cut for just 60 $ and
do it right,without any engine codes and stalls :sarcasm:
Speed cut at 180 km/h is stupid...:naughty:
Can't even hit a rev limiter with my 3rd gear.....come on guys be serious!
foreverpsycotic;1024678 said:$60 of free, I will take free, as the SCD does the same thing, clamps the signal between them. CEL only goes on if the cargoes over 120, and goes off after you restart the car.
Dylan JZ;1025051 said:you truly are the stereotypical mk3 owner lmao.. j/k
foreverpsycotic;1025354 said:Tell me about it, I payed $40 for my Holset.
