Custom cams came in....*pics*
williamb82
907
4
Tampa, Fl.
damn!!! stock lift is ~6.7mm, the old hks cams were ~8.1mm lift. i planeed on some 264deg cams at 8.5mm lift myself, but im a cheap poor bastard and am going to get regrinds. lol. cant wait to see what that monster puts down.
william
SupraRacer
255
St. Louis
Wow, i just cant see those things being very quiet. they are going to slap like a mofo. id almost be worried about throwing a shim.
The sound will change a bit, but if its anything like a camed jz motor, you wont be able to tell.
figgie
Twin Cities, Minnesot-ah
at 288 duratiuon.. like hell you won't ;)
VanSupra
Van,B.C.
williamb82 said:
hows he going to do that when he bought shim under buckets? there is no shim on top for the cam lobe to throw.
Exactly.
Slow, even with my TRD cams(which are pretty chunky) also which I don't have the specs on yet, but even they won't idle below 1200 rpm comfortably because of not enough vacum.. @1200-1300 rpm the engine is making 9"s of vacum but it sure don't sound anything like the stockers. :naughty: Keep up the excellent work as you are the trail blazer for all of us.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
humm your's make's mine look so small oh welll what cna you do
you must be low comp useing these cams
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
To all those screaming for vids, dont worry, there will be plenty of dyno video to go around :)
Right now im predicting my idle to be at 1400ish, but we'll see. The best part is that these cams arent even the coolest thing that i'm doing. I have some secret stuff that i havent told anybody :D Once its running and dynoing, i'll spill the beans :)
Iron Tank
Grease Monkey
N. California
Those cam lobes look mighty aggresive. It will be one hard core 7m once its done. :icon_cool Good luck with the project.
I will be testing a set set of toda 264's with 10.3 mm lift on mine soon. :icon_bigg
