MarkIII4Me;1572565 said:Did you make sure to prime the turbo properly prior to firing up the engine? If it was ran dry, even for a little bit, it can damage the bearing and cause shaftplay. Enough shaft play can cause the wheel to come in contact with the housing; which can lead to bent fins.
Not saying that's what happened. Just throwing that out there. Though your fins appear to have come in contact with some sort of projectile.
how do u prime the turbo exactly??
