there is 4 allen key plugs inbetween the valve covers, are they there just for casting purpose??
now another question, i'm doing the na-t and i was wondering if i could drill and tap one of those plugs and run my turbo drain into the top of the head?? i know its a little higher, but it must be under some pressure when leaving the turbo. could i just drill the valve cover??
does anyone know what those little valves are for underneath the intake manifoly, have two vacum lines to them, and one 2wire plug from the harness.??
does anyone got a vacum line schematic, turbo intake and throttle body is a bit different.
:aigo::aigo::aigo::1zhelp:
heres the picture the plugs are removed,
