Okay so i pinpointed my radiator to be causing the loss of water, and so i replaced it, it HELPED, then i got a new thermostat and rad cap, i topped the coolant off, drove it around no coolant gushing noise, on the way back home, LOTS of coolant gushing noise. Did the same next day topped off then gushing noise after about 20 mins driving. The coolant overflow bottle seems to be playing around the min and max levels and returns to normal the next morning, but i still have to add coolant maybe about 1/4 cup? My question is, where else could it be leaking, coolant did not have any combustion gases, nor was the heater core leaking, it just loses water after driving a long time, engine oil is the normal color and the exhaust doesnt have white smoke unless i first start it then it goes away, where could it be coming from? there are no visible leaks nor any noises of any coolant spraying. anyone could possibly help me? let me know, thanks!
edit: after replacing my radiator i did notice the temp gauge never went up past its normal temp, it would use to occasionally go up then back down, now it doesnt...
