coolant problem...
Jimenez42
17
Michigan
I went to burp my system today because i had just replaced the radiator cap and had noticed that the coolant had been going to the overflow bottle when turned off and returning to the radiator when the car is turned on....Anyways i turned the car on with the radiator cap off and the coolant in the radiator started to rise and overfill the radiator and also while doing so the coolant started to Foam a little...Anyone have any ideas to what is causing this?
I have searched but couldn't find any thread specifically dealing with this
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
waterpump bad ??? hmmm maybe too much coolant ??
I found out that my waterpump is bad and ill be changing it some time this week.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
hrm i swear half of all of the threads on supramania deal with coolant in one way shape or form ;););)
Asterix
Lurker of Power
Vienna, VA
Two things come to mind: 1) a clogged radiator and 2) your thermostat is stuck open.
The coolant really shouldn't flow with the engine cold because the thermostat is closed. If your coolant is flowing when the engine is cold, your thermostat is stuck open.
Because water expands when heated, it's normal for a little to go into the overflow tank when the car is hot. It returns to the system when it cools down and the water shrinks.
Asterix
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Its supposed to rise as it heats up, and there shouldnt be a need for burping the system when you replace the radiator cap, since its at the top of the system and air comes up there naturally, just top it off.
