Coolant leak from where??
suprachief
10
st. john's
I just finished a complete engine rebuild. The engine is up and running finally but I have water vapour from the tailpipe once the engine has been runing for a couple of minutes. I checked the compression & it varies between 142 & 150 psi(wet).
Does this mean that the water vapour is coming from the turbo charger, or is it still possible that the head is leaking sightly? Any suggestion would be greatly appreciated. Thanks.
toyotanos
What will we break today?
2,842
Coon Rapids, MN
Is it just water vapor coming out? If so, that's a normal by-product of an internal combustion engine operating.
If it's a plume of thick, sweet-smelling white smoke, then you may have a problem!
suprachief
10
st. john's
Thanks for your time. There is a slight smell but not overwhelming, maybe I'm just a little paranoid. There were a few hiccups with the rebuild.
paradox616
472
Melbourne, Australia
was the motor at operating temp? if the exhaust is still cold then of course its going to steam!
like if you breath hot air on a cold day :)
first start paranoia is normal! :)
PROJECT N00b
XBL: Mkiii DriFt3r
May 22, 2005
1,660
honolulu, california
i have to ask this question since the thread is already up. im having a coolant leak problem, i found where it coming from but i cant seem to stop it. the steady stream of coolant is coming from the mount where the clutch fan pully is mounted to on the front of the block.
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
That "mount" is your water pump.
lewis15498
Sep 28, 2008
1,397
PROJECT N00b;1401617 said:
ok i figured, well its coming from there, i checked to see if any of the bolts came loose, but they arent.
Waterpumps are dirt cheap (compared to oil pumps) Driftmotion sells them for 55, my local guy can get them for 35. sip racing has one with a better impeller design for 70. You get what you pay for, but none of the above are going to leak. Besides its a good idea to change it even if thats not whats leaking. Go do work son!
mkiii222
Troy, MI
Plan on ~2 hours and taking the radiator out (makes the job soooo much easier). Good time to change the belts too.
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
Chief, do you lose coolant?
Noob, if you didn't know what the water pump was you should probably change it. As said, get a decent one and change the belts too.
You'll get a new WP gasket with the pump.
With the rad out, inspect it. Flush the block
