IwantMKIII;1134574 said:I live on earth. While PROGRAMS may not be as stable on vista, Vista itself is far more stable than XP. Vista has NEVER froze on me or blue screened me for any reason, anything but the case for XP
Maximum PC - This Month's Issue: "Inside Microsoft's $6 Billion Failure"
I have run XP Home, Pro and Media Center Edition 2005 since the beginning of 2002. They have graced graphic cards as old as GeForce2 up through X1950 Pro. Processors have been Intel 733 MHz, AMD Athlon 1.2GHz, Pentium 4 2.4GHz, AMD Sempron 2300+, Celeron 2.53 GHz, and an Opteron 165 [dual 1.8 GHz], PLUS the variety of motherboards to support them. I have used onboard LAN and PCI network cards, onboard sound and a few models of Sound Blaster cards, onboard IDE controllers and Promise IDE controllers, and an onboard SATA RAID controller.
This is a large variety of hardware, so the chance that I would encounter bullshit is pretty high.
I remember I had a blue screen incident once when I was fiddling with things and a SATA cable came undone while the computer was on. That's about all I can remember.
I experiment with software and hardware all the time and I stopped using virus protection in 2006. I use Spybot Search and Destroy, surf with Firefox and view media with Media Player Classic. I use legitimate software that is either freeware, or that I pay for and I have ZERO PROBLEMS. If you have problems with XP, it's either your hardware, drivers or something YOU are doing. If your exact setup does not work with XP but DOES work well in Vista, I would suspect crap/wrong drivers used in the past.
