Which is better, if this can be generalized so widely.
2 GB DDR PC3200 running Dual Channel or 3 GB DDR PC3200, not dual channel.
terror;1134454 said:dont go to vista, xp is so much faster and has less compatiblity issues
no, you either have DC enabled or not.Justin;1134378 said:So would I be able to run two sticks of 1GB in dual channel form and a single stick of 1gb in single channel?
Justin;1134378 said:I have two gb right now and want to know if I should throw in this additional 1gb that I have available or not
IwantMKIII;1134559 said:Vista, while more demanding, is far more stable. We run 8GB of ECC mem on our workstation with it. We do some very intensive CAD designing software though.
Dont forget, XP support will be DICONTINUED SOON. Vista will have a REPLACEMENT already next year supposedly. Keep this in mind. My source of this info in the head tech of the engineering dept. at WVU
Facime;1134572 said:XP (32bit) cant access more than 3GB ram anyway so if you are running XP and more than 4GB you are wasting your money.
Vista more stable? In what alternate dimension are you living. And who gives a rip about support when you have a functioning system? I service both systems and I still say, FOR NOW, xp is still the better OS for MOST people. Get Vista if you like eye candy and the apps you run are mainstream and up to date.
IwantMKIII;1134574 said:32 bit OS systems can access 4GB of memory.
IwantMKIII;1134606 said:proof?
Facime;1134609 said:Been discussed in 100 or 1000's of threads. This seems pretty definitive:
http://www.microsoft.com/windows/windows-vista/compare-editions/64-bit.aspx
you bios will see it but the OS will not.
IwantMKIII;1134612 said:yes, its a microsoft article, still fails to tell me why only 3GB is usable. 32 bit still has the ability for 4GB
Poodles;1134627 said:From what I understand anything over 3GB will overrun to the rest of the RAM instead of be actively placed and controlled like normal...
You're both wrong, XP and Vista are both unstable![]()
