Compression tester stuck in plug hole (F*ck.)
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
My compression tester is stuck in the #1 spark plug hole. Its the threaded type with the O-ring seal. Any idea how to get this thing out without taking the engine apart. Compression was 185 BTW.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Maybe there is pressure becaue the piston is at the top.. <-- dont listen to me I am a noob and pulling stuff out of my ass.
I'd sacrifice the tester before I took the head off. Could you get a socket over the thing if you cut the hose off even with the spark plug well?
Yellow 13
Lurker
Apr 4, 2006
2,308
Im just gonna get another HG and some ARP headbolts. I planned on pulling the engine up to do that pilot bearing like I shouldve anyways.
Ive at least got the piece of mind knowing that it fired up and ran.
gixxer750
2jzget comingsoon!
Mississippi
dude. if it's a two piece just unscrew the hose and put a 5/8 spark plug socket on the adapter. If not, pull the center valley cover and slide it up so you can get access to it.
americanjebus
Mr. Evergreen
wa.
u should just go ahead and rebuild the block while your at it, and while thats out redo your wiring harness and while thats out you might aswell repaint.
bluepearl
326
pa.
How bout, the extra long needle nose pliers. You probably just need a little extra effort between the hose and the crimped fitting.
