most GTE's are around the 150 mark 128 is the minimum and is indicating a very tired engine, more importantly is the 14psi variation allowance between cylinders.
the car has been sitting for a little while so today i went to the store and got some top end cleaner, after i run that through and redo a compression test what conclusions can be drawn if the 5 and 6 cylinders compression comes down?
