Compression on 5 and 6 way high
burge31
4
rochester
Did a compression test on all the cylinders, 1-4 were up to specs but 5 and 6 were reading 180....any suggestions on what this could be?
burge31
4
rochester
the other cylinders were 130 which is up to specs, im just trying to figure out what could cause the 50 psi difference
Ummm where did you get 130 as a spec?
most GTE's are around the 150 mark 128 is the minimum and is indicating a very tired engine, more importantly is the 14psi variation allowance between cylinders.
Is this a GTE or an NA/t?
burge31
4
rochester
the car has been sitting for a little while so today i went to the store and got some top end cleaner, after i run that through and redo a compression test what conclusions can be drawn if the 5 and 6 cylinders compression comes down?
