Ma70.Ent said:What's with all the Vette vs Supra related threads lately, lol.
IJ. said:Chunks: Sorry that's not "many" that's a few......
IJ. said:"Reliable" is a very subjective thing Chunks...
Most of the 500+ cars you're talking about see very limited use and not much of that time is at peak power output.
I tend to hammer my car whenever I drive it as that's what it was built for but even so I wouldn't be calling it "reliable", the one thing in it's favour is it's always made it home under it's own power no matter how badly I've broken it.
A 6.0L motor is going to be far less stressed making it's 600 than a 3.0L and this is at the expense of longevity.
nosechunks said:True but an 6.0l engine making 600 horsepower in a street car will see that same time at peak output as a 7m making 600 horsepower
nosechunks said:You say more parts equal more parts for breakage, thats against the lsx right? 2 less cylinders, no hydraulic lifters, pushrods, rockers, the only parts a 7m has that the lsx doesn't is one more cam and 8 more valves, but the probability of a valve or cam breaking isn't more then a hydraulic lifter, pushrod or rocker breaking.
A 500horsepower 7m wouldn't have crazy lag, but the lsx would have more area under the curve, BUT a n/a 500 horsepower ls1 wouldn't be as street friendly and smooth as a 500horsepower 7m. and 7m's have 2 more main caps for reliability.
This could go on for days, the bottom line is If there both built right they'll both last as long as you would need either one to last without issues, BUT the 500 horsepower 7m would be cheaper and more reliable for the same money as swapping to an lsx and making the same 500 horsepower..
Those parts would be the same from 7m to ls1 and are not engine related. an IC coupler blowing up isnt a reliability issue with a 7m but any turbo car and good silicone couplers dont blow out very often.Wiisass said:If you want to nitpick like that about the number of parts, then you're going to need to count every coupler, IC pipe, hose clamp, vacuum line, etc. That stuff can also break and if it's a turbo or an IC or whatever, it's going to be expensive.
No i was saying Either engine in a street car will not be making full power at all times. to make 500 horsepower n/a youll need a lumpy cam, headers, heads. its not going to idle as smooth as a turbo car with way less cam overlap, cruising would be smoother, idle would be smoother. i did say area under the curve would be better for low end, but if your rolling down shifting takes care of that and lag isnt that bad even of a really large turbo.Wiisass said:So you're saying a 7m would be more streetable because unless you're beating on it, it would be making stock NA power when driving on the street because of the lag? I'm a little confused at that? So that means that it's better than a car that makes power everywhere? Is that just for people who can't drive or for everyone?
Again i still dont see why a properly built engine of any make and model would have any issues with reliability.Wiisass said:I still don't think a 7m would be more reliable or cheaper. Unless we're talking about different reliables. I said what reliability should mean and that's driving the car to the race track (road course/drift/autox), beating on it all day, not having to touch the motor and then driving it home. Drag racing doesn't count for this because if you're breaking your motor drag racing, then it wouldn't last a lap on a road course.
i took prices from average places that the average person would get them. YOU might have a good hookup and get everything at a sick price and thats cool but not everyone can, thats why i went with whats readily available on ebay for the engine tranny combo.Wiisass said:So reliability with the 7m, they can be reliable, but I don't see it being any cheaper than an LSx. You're list earlier was a little off and when I adjusted some of it, the price would've been the same and that's considering that you're getting ripped off on the LS1 price. So as long as you know how to spend money, you can get an LS1/T56 for about the same as it would cost to properly build a 7m. So the motors cancel each other out. Then you need to add on all the necessary parts, to make the power and keep the motor reliable. And even if they cost the same overall to make the same peak power, it won't be the same power. Peak power doesn't mean anything. I mean a 500hp 7m wouldn't fully spool until what 4k+? So the LSx car will making a lot more power below that and then the 7m will have to try and catch up.
Where are there More failure points in a 7m, it has less cylinders and more mainbearings??? i agree parts in a 6 cylinder are more stressed at same power level of an 8 cylinder, but i still don't see where these extra high stress critical parts are in an engine with less cylinders.Wiisass said:And along with the reliability, the 7m has more failure points. Which doesn't mean that it's less reliable it just means there is more of a chance of each of those parts failing. The LSx also has parts that could fail, but it's not as highly stressed at the same power levels, so the fatigue life of the parts is going to be higher than on a 7m.
Tim
7Ms have 2-bolt mains if I remember right. LSXs have 6 bolt mains. How big are the rod and main journals on a 7M crank? The LSX uses a 2.1" rod journal and 2.56" main journals. So basically the 7M is likely weaker in this comparison as I am pretty sure it's journal sizes are a bit smaller.Where are there More failure points in a 7m, it has less cylinders and more mainbearings??? i agree parts in a 6 cylinder are more stressed at same power level of an 8 cylinder, but i still don't see where these extra high stress critical parts are in an engine with less cylinders.
Pretty sure you are only saying that because you don't really know how to "properly" build an engine.Again i still dont see why a properly built engine of any make and model would have any issues with reliability.
i dont see any sheets or attachments, not that it matters so dont bother anyway, your arguing to argue. i never said it couldnt be done, i actually said it could be. though even you yourself says the cam is a little "aggressive", turbo cams have minimal overlap therefore smoother. i don't know what else your trying to prove. Facts are turbo cams "should be", if degreed in properly, smoother then any actual performance n/a cam. an engineer such as yourself should know that.SySt said:Ok, i'll show you a dyno sheet of a 540hp LS1. blah blah blah. Now your turn, show a ~550hp 7M dyno graph.
2-bolt but 2 more, and one piston per throw. seeing as people make 600+ with no more then MAYBE billet mains i dont see your point. you have double the load we do on the same spot on the crank and we have 2 more mains supporting the crank. 2 more mains supporting the crank is much more then having journals "a bit" bigger.SySt said:7Ms have 2-bolt mains if I remember right. LSXs have 6 bolt mains. How big are the rod and main journals on a 7M crank? The LSX uses a 2.1" rod journal and 2.56" main journals. So basically the 7M is likely weaker in this comparison as I am pretty sure it's journal sizes are a bit smaller.
Oh yea i forgot, your an engineer AND now a professional engine builder, is there any acronyms i should know before i build any more engines? A properly Built engine is just that, an engine built/assembled with parts that can properly handle the power and rpm desired. If the parts in the engine can handle the power and rpm how are they unreliable? Stock, yes i agree a stock 7m at 500 horsepower is unreliable because its a guessing game at when it will let go.SySt said:Pretty sure you are only saying that because you don't really know how to "properly" build an engine.
SySt said:Lets compare a 400HP 7M build to my LS6 swap. I have maybe 3k into my LS6 with 5k miles on it including the fully tuneable PCM. Now how much does it cost to build a 400hp 7M with a fully tuneable PCM? I doubt it is much cheaper if at all.
SySt said:The 3k IS the cost of the engine + ECU. I do know a guy at a GM performance shop where I purchased the shortblock. However it was 2k and was not much of a "great" deal. There is no money spent on putting the swap together really, as I have done all the work myself.
I have to strongly disagree about turbo lag not being that bad. I had a stock CT26 on my 7M and that was about all the lag I could stand.
What sort of logic are you using in saying if engine is properly built to handle the power/rpm then it will be reliable? Of course any engine designed and built to run a given power/rpm will be reliable. The problem is you can not change the block or the heads on a 7M really. You can throw whatever crank, rods, pistons and bearings you want into the 7M. Eventually the block will become the weak point. For instance, even with the best (proper) internals you are not going to be able to run 20k rpms on a 7M.
Now that we are on the subject though, there ARE aftermarket blocks and heads available for the LSX. You can get a block with 5 bolt heads and a set of heads with 6 valves/cyl. for an LSX.
nosechunks said:Damn, you mean i cant make 10khp and 20krpm??!!1!1 :rofl:
ct26 lag? They shouldn't be in the same sentence, or you have serious engine issues.
Blow and head change for power handling isn't necessary.
Wiisass said:Very long post.
SySt said:Changing the block is not neccessary for handling large amounts of power? You are find stock block and heads at 500 no doubt. What about 3k horsepower? I guarantee you would run into problems with the block and head. I was simply saying that anything "properly" will work great. However sometimes you can no "properly" build an engine due to design restrictions.
nosechunks said:Anything could happen with those parts i understand, but thats also not horsepower dependent, thats regardless of output they could get damaged.
idle quality and streetability has everything to do with this discussion, were not talking about race cars, were talking about streetcars.
Position of the engine is up to installer besides the lack of 2 cylinders sticking in front of the 4. It is a light engine, that is agreed.
Cost varies, its all relative, they might be cheaper in your area then mine and might be even cheaper then for the next guy, no biggie.
I dont think duane's, nate's, or anyone eles ESPECIALLY IJ's cars are trailer queens.
I have said low end isn't the best with turbo cars. fastest turbo car ive been in was my buddies grand national. t70 went 10.90's breaking up in third. Even that lag isn't that bad, maybe its just me. i don't mind the lag because i love the feeling of boost coming on.
The thing is we went from talking about lsx swap in a street car, to talking about a balls to the wall 2khp Race car. No street car is perfect on the track, and no street car is perfect for racing.
yea 3000 horsepower in a street car. 500hp to 3khp, screw it lets go for 5khp. :icon_roll
