Coilpack relocation done
Status
Not open for further replies.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I'm interested Aaron. Let us know the price, I'll more than likely hit you up ;).
BTW: the damn post office wouldn't drop off the exhaust stud kit you sent me, so I gotta remember to go there Saturday and pick it up :(.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
QWIKSTRIKE said:
can you show howin deail the isc was done. My ffi doesn't have one but I can use this idea to assit with cold starts
Thanks
The isc is still in the stock spot actually, I ran out of time to work on that before Vegas, and I have been busy with a bunch of other projects since. I'll do a write up on it when it is done.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Aaron, do you think the EGR flange on the back of the manifold will flow enough for the ISC to function. I was considering this location because it would be even more hidden than the front vac port.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Hey, that is a great idea man! That should be plenty for the isc. The isc is just a controlled vacuum leak so any larger port on the manifold should work.
I had put a 1/2" npt fitting on the back of my manifold for the maft pro temp sensor but I moved the sensor so I was going to use that, but the egr port might be easier for people who don't use the egr.
Status
