DeMoN2318;2010197 said:Who said anything about it calculating anything?
DeMoN2318;2010072 said:More air...more fuel...maintain idle AFRs...raises fuel cut.
jony89;2010225 said:does anyone have bic down pipe they’d like to I’ve me their review about?
Nick M;2010229 said:Seriously?
How do you think it comes up with the correct pulse width and timing? By guessing? It is calculated with look up tables based on airflow and engine speed/position data.
DeMoN2318;2010235 said:I have a BIC DDP and if I were to do it again I would get the recirculated one...the DDP is way loud when the wastegate opens
jony89;2010302 said:get into trouble with it? as in cops and tickets?
jony89;2010322 said:Alright I have another question, since im running 500cc inj with the lex mod iis it possible that im runing rich on idle but lean under boost? I cheked my plugs again moments ago and the rim is black but contcts are alittle lighter with some I guess u can say white. wish I had a wideband righy now
the car seems to fall on its face after 4k rpms then comes back, doesnt happen in 1st gear, 2nd gear jyst alittle and 3rd&4th is were its felt the most. I checked for codes but it just flashes rapidly so no codes
Any ideas?
hvyman;2010372 said:why would you be lean with 550?
If you dont know dont post. this is the tech section.
DeMoN2318;2010702 said:Yea, you can tune it with a SAFC.
Usually people use a dremel to create a slot for a flat head screw driver...
In would make it less lean, but if you are going to tune with a SAFC, then just set it and leave it.
I think all the way out will allow more boost since that will allow the maximum amount of unmetered air to pass
IndigoMKII;2010719 said:All the way out will make it even more lean.
