I figured I would update this as it appears my problem is fixed now
Two weekends ago I went ahead and used my DMM to test my harness. No continuity was present between the lead wires and ground, and I was getting 1.6V with the EFI fuse in and when the ECU has power. I went ahead and installed my original front knock sensor into the center hole and connected it to the KS1 (my front) lead to see if I could reproduce the symptoms I was having before I started messing with all this. I re-tightened all the sensors and I drove it around for that week and no CEL
This past weekend I went ahead and removed the new-to-me KS out of the front bung and reinstalled my original gray plug KS into the front bung and reconnected it. So far no CEL, hopefully it stays that way.
So the only thing that I can think of that was causing the intermittent CEL would be that both the front and rear sensors were fairly loose, the rear sensor started to spin when I was trying to wiggle the connector off... I re-tightened the rear when I tested the harness, snugging it up before reconnecting the KS lead.
I am guessing without being torqued down, the KS gets an intermittent ground, correct me if I am wrong but I believe the case of the KS is the ground?
Thanks for all the help while I sorted through this problem. It always helps to talk things through, sorry for those who were annoyed with the incessant questions.
Have a great week!
