code 14 ... haha :(
code14
USA
hrm... this is getting sweet.
there's a lil connector lookin thing by the power steering fluid reservoir and it snapped off the wiring harness... super brittle... sweet. can i just, uh, solder it back on??
OT: how much would a new wiring harness + install set me back? :\
isnms
United States of America
Oklahoma
i80.photobucket.com
there are a bunch of connectors near the ps fluid reservoir. some may need some soldering to fix, some can be fixed with crimp on quick connect connectors.
a new harness is around $400 and that does not include install
code14
USA
well, i guess ill get to that later :(
so for this :: ahem :: spark test....
you remove all the plugs then attach them to the spark plug wires?? and then crank it? that seems like a bad idea... or do i remove one at a time??
last time i just stuck a screwdriver in the boot... but that's prolly not the safest way to go ;]
8,897
You only need to pull one plug wire. Put a spare plug in it, and ground it. Have a buddy crank the engine so you can see if it is sparking.
If you are having an intermittent problem, then you don't likely have a component failure, but a bad connection. And this test might not show you anything.
code14
USA
well, they all sparked... :O
gah, i'm pretty sure it's electrical :(
i guess as soon as i get my hands on a voltmeter i'll check the resistances of the wires. shoot, well, thanks a lot for all the help guys!
you all know a wee bit too much about these cars... it's freakin me out ;]
later! and happy driving :]
