hiya!
so my car will run fine... then suddenly the rpm's will bounce around, check engine light comes on, then the car dies. also, while i'm cruising, the car will uh, stutter(not sure if this is a related problem or not). i'm guessing that can't be a good thing. then to top it off, the car won't start. i was stranded in an intersection for a good 5 minutes before the car decided to start back up again... yay!
well, i got me a code 14, and i did the whole spark test thing... and they all sparked. are there some other things i can check??
thanks again!
thanks again!
