clutch help, i keep breaking pressure plates
Status
Not open for further replies.
di_rosa
never ending project ...
Apr 2, 2005
215
toronto
if it wasn't machined perfectly flat, i would have vibration/chattering when i was engaging the clutch, but i don't. everything is perfect up until it blows.
and IJ, how can i check for this center line being off? if all the bolts are all tightened, if the tranny mount is on and everything *looks* center in the tranny mount, and the engine looks centered in the bay and both the engine mounts are in tight, i don't know how else to check this center line?
DiRosa: Really not sure how you'd check a 154, normally what I do is to mount a dial indicator to the crank then turn it through 360 degrees make any corrections needed from there.
Can't do this on a 154 as the Bell housing doesn't have a round hole to indicate off.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Man this is a wierd one, I would try and go back to a 7m flywheel and a 7m bell housing. :dunno:
I don't really know why... :(
di_rosa
Apr 2, 2005
215
toronto
ah......so i'm screwed there.
well, i'll try examing the flywheel and crank, and how far out the crank sits, and everything. i'll let you guys know.
di_rosa
Apr 2, 2005
215
toronto
originally yes, but then i threw on a flywheel and manual trans, and called it a day. and no, i did not re-use those shims between the flexplate and crank
Clifton
Scottsdale, Az
I would check the input shaft for straightness. You would need a dial indicator for this too. Go to Harbor Freight. They have them and magnetic bases cheap. Where did you get the dual diaghram PP from?
di_rosa
Apr 2, 2005
215
toronto
local shop in toronto that builds them.
yeah, i'm pretty sure the input shaft was fine cause it was pulled from a perfectly fine running car, but i will double check again. but if the input shaft was slightly bent, i'm pretty sure it would be causing some hardcore vibrations. either way, when the tranny comes out for the 7th time in 4 weeks, i'll re-check everything, and maybe swap in another tranny.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
$1500 for a "good" clutch? no, thats a "fantastic" clutch.
I would source another R154 and put that on when you do the clutch again.
di_rosa
Apr 2, 2005
215
toronto
yeah, i have another r154 i am probably going to try next after i rip it all apart again, and verify the flywheel hieight and some crank specs. hopefully someone will have their engine outside of their car so i can compare my measurements to theirs.
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
this is fuqed guys what is going on here.. Even i'm stumped how can you break something that shouldn't be spinning that way.
di_rosa
Apr 2, 2005
215
toronto
what if i have crank walk? it woud kinda explain why it only happens when i floor it (crank pushes forward and somehow causes pp to break). also, i've noticed that i have a slight vibration that goes up with rpm, but i just assumed it was a loose engine mount or something touching the frame like my stupid ebay manifold touching the frame. it would also explain why my original 1st pressure plate lasted like 5-6 days under my heavy foot, compared to me roasting a pressure plate in less than 2 hours of driving now; damn jdm engines. i dunno, just shooting out ideas.
di_rosa
Apr 2, 2005
215
toronto
bah, must have been a gte swap, or it was an '87, i don't remember
but if it's a bad flywheel, how can you tell?
di_rosa
Apr 2, 2005
215
toronto
well, pulled the tranny and flywheel today in the rain, and i've verified the bolt holes in the flywheel are the correct size as they match perfectly to the ones in the stock w58 flywheel (a spare i had laying around) bolt holes.
so does anyone know how to measure the flywheel step? i was thinking of getting a straight edge, laying it on the contact material of the flywheel (part that touches the disc) and trying to slide feeler gauges under it where the pressure plate bolts to. anything wrong with that?
also, is there anything else i can check on the flywheel? anyone got one handy to take some measurements for me to compare with?
i have compared my flywheel to my old w58 one (don't have another r154 one handy), and the my current one is like 1/4" taller (just eyeballing it). could someone take a measurement of it's height with a caliper? i've measured it's height with a tape measure, and it's about 1.25", so i would guess about 1.30" total height with a caliper.
thanks for everyones help/input
di_rosa
Apr 2, 2005
215
toronto
no no, i just had an old w58 flywheel to compare it with, i'm using the proper release system and proper clutch and proper flywheel
Status
