i keep breaking pressure plates (refer to pic below), and i'm fucking tired of doing clutch jobs every week. i've gone through 3 pressure plates, and every time, before it blows, everything is working perfectly, engages smooth, no shuddering/chattering, holds fine, no slipping, clutch pedal feels normal, and then on a 1st or 2nd gear pull (around 4.5k) boom, it breaks, engine starts wobbling (due to unbalance), and it's hard to shift into gears (due to pp not releasing because it is bent/broken).
the pressure plate is from a clutch shop that rebuilds pp's and makes them stronger via dual diaphrams, stronger springs, etc, etc. every time it has broken, they have replaced the rivets, bands, and checked it all out. i don't think it's the pressure plate as other people have the same pressure plate with no problems.
tranny is stock r154 from 86.5, however, my friend had it sitting outside under a tarp for a bit, and when i got it, water came out, but like i said, car drives mint before the pp goes.
slave cylinder is from a jdm soarer if it matters, master cylinder is brand new, using dot3 hydraulic fluid.
flywheel is from 1jz, and has all he dowel pins on there. bell housing is from soarer r154.
it's almost like the 2nd part of the pp (friction material part) is twisting away from the other part of the pressure plate.
thank you for any suggestions you may have. i am going to try one more time with a stock pressure plate, and see what happens, but i fear it may not happen again because the stock pp is slipping.
