Climate control - only one speed
alexscof
70
Pullman, Washington (WSU)
Hey all, ever since I got my car everything on the climate control has worked great except variable speeds. All I have is off and low. Medium and high don't change anything. The lights for those buttons do light up. Thinking it was a logical place to start I bought a whole new climate control unit. Just tested, same thing. What now?
shaeff
Kurt is FTMFW x2!!!!
11
Around
Blower motor resistor, located on the passenger side, just to the left of the blower motor. It's mounted on the bottom, one screw to remove it.
Note: make sure you reinstall that screw properly, because if you don't the resistor will fall out and burn a hole in your carpet/floor mat.
