Ckanderson said:I've tried this.. this has been around for ages.. didnt notice any difference.
really? even at the mixtures they explain 3.4oz to every 10 gal
what Octane where you using?
Can I improve fuel economy by using quality gasolines?
Yes, several manufacturers have demonstrated that their new gasoline additive packages are more effective than traditional gasoline formulations. Texaco claim their new vapour phase fuel additive can reduce existing deposits by up to 30%, improve fuel economy, and reduce NOx tailpipe emissions by 15%, when compared to other advanced liquid phase additives. These claims appear to have been verified in independent tests [30]. Other reputable gasoline brands will have similar additive packages in their quality products. Quality gasolines, of whatever octane ratings, will include a full range of gasoline additives designed to provide consistent fuel quality.
Note that oxygenated gasolines must decrease fuel economy for the same power. If your engine is initially well-tuned on hydrocarbon gasolines, the stoichiometry will move to lean, and maximum power is slightly rich, so either the management system ( if you have one ) or your mechanic has to increase the fuel flow. The minor improvements in combustion efficiency that oxygenates may provide, can not compensate for 2+% of oxygen in the fuel that will not provide energy.
bobiseverywhere said:I hope some people can test this out,
Zazzan the point of using it is that is breaks the surface tension of the Gas. That in theory could actually help. anyway i don't have a car to test it with unfortunately so i hope we get a few people giving this a try. I have a friend of mine who might be giving it a try
Zach said:My skepticism comes from the fact that he rags on alcohol when alcohol is PROVEN to reduce detonation at elevated boost levels on pump gas. If acetone does the opposite of alcohol, then it will theoretically increase the possibility of detonation.
Ckanderson said:i KNOW someone on here has to have like a crappy suzuki swift, or geo metro to try this on...
bobiseverywhere said:thanks jdub for the info
and figgie they talk about breaking the surface tension of the fuel or gas not that the acetone it self is what is causing it to be better but help in better using or more efficiently using the gas you have in your tank.
