Cheapest way to reach 400whp (1JZ-GTE).
lifesnotfair
356
Dominican Republic
Hrm... I remember reading abou that guy who, on stock twins and HKS cams got all those HP and TQ numbers. He was running 18psi though, which I hear are a bit too much for the poor stock twins? I could be wrong, but isn't the "rule" to not go over 14psi on the stock twins?
lifesnotfair
356
Dominican Republic
OneJoeZee said:
Enlighten me here bro, what is the max PSI the stock twins can take without having their lifespan greatly reduced?
Also, I looked at 935motorsport's single turbo kits, and although I couldn't tell much from the description, it does sound attractive. They have 3, one that says in the description is good for 350WHP, another one for 400 and another one for 500, and it's "bolt on", something you can do "in one afternoon".
Does this really work that way?? Allow me to copy/paste exactly what it says. This is the one for 400whp (so it says).
- Stainless Steel Manifold
- Complete Oil Line Kit
- T04S Turbocharger or GT35 Comparable Sized Turbo
- P Trim T4 Turbine (.70 to 1.10 AR)
- 4" inlet Filter and Intake Kit
- 3" stainless steel downpipe and vband clamp
Everything you need, to bolt on this kit in an afternoon is included. This setup will give you 400 at the wheels, and a overall HP capability of 550.
*** that's what I read. So, as I'm not very knowledgable about it I have to ask: if I buy this, have my mechanic install it, and that's it? As easy and simple as that? Stock ECU will be fine, and stock intercooler and stock everything else??
OneJoeZee
Retired Post Whore
aboard the Argama
Run however much boost you want. When most people's turbos die, its because their turbo seals gave out on them. that will happen at stock boost or elevated boost. Many members are running over a bar of boost daily for a while now.
CT12a's can't be run over 14psi just like the 1J has no torque...
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
Do you know what the Max PSI you can push on the stockers before they become inefficient.
I understand with the CT26 its 12 -14 PSI before you a genterating more heat then boost with the turbo. it's efficiency limit
whats the deal with the CT12A's And where is Fuel cut on the 1JZ?
OneJoeZee
Retired Post Whore
aboard the Argama
not sure about efficiency. People with full exhaust(ypipe included) are probably hitting 16+ psi easy. If you wanted to mess around I guess you could turn it up even more.
fuel cut is at 1BAR(IIRC). I've never hit it in my car. On cool night here, it always creeps right up under 1bar but never hits it. kinda funny...
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
mattjk said:
There is a guy in austrailia putting down 390rwhp at 18psi with hks cams and a pair of these. http://cgi.ebay.com/PAIR-OF-CT12-A-...1QQihZ017QQcategoryZ72478QQrdZ1QQcmdZViewItem
and someone on supraforums is putting down 370rwhp with the stock twins.
Yup and the 370rwhp was done on a stock ypipe and 262 cams iirc. I believe with 272's, an upgraded ypipe, a good tune and maybe a few more goodies it would be possible to hit 400rwhp with the stock twins. I believe Joe was the one that said that it looks like cams and a good tune are what you need to get power out of the twins. But is it worth it? The twins are my only worry with this engine as "its not if they're gonna blow, it's when".
IMO the easiest and cheapest way to get 400whp is to go with a nice single setup. Just look around at other people's setups and find what you want.
bobiseverywhere
bobb'n for money
Montreal
sweet i have from the Y-pipe back well atleast once it's installed LOL
ranger2339
Battle Ax
Apr 6, 2005
70
La crosse WI
Ha ha some of the responses in this thread are just fucking funny!
Just go with a small single and some 440cc inj. and you will get 400whp or go BPU and get 300-350whp and have fun with that.
Ax
bobiseverywhere
bobb'n for money
Montreal
Ax
What do yuo mean man
Not that i know exactly about the 1JZ
but i have seen people pull more power out of the 7M on stock components then people with huge mods that cost a heap of allot more
if you know what you are doing. It's amazing what you can get an engine to produce and with very little extra.
lifesnotfair
356
Dominican Republic
Everyone mentions the "better throttle response" of the twins... well, I'd obviously expect them to load faster than a single, but still, when would the single hit full boost? .. I like the idea of the single better as it doesn't seem to involve opening up the motor, as changing the cams does.
bobiseverywhere
bobb'n for money
Montreal
depends on the turbo and it's setup.
when i said twin you could also go and get a aftermarket twin setup as well. To keep some amazing throtle responce while still allowing for the needed air flow on the high end.
Obviously though running twins as oposed to a single is more expensive in general.
OneJoeZee
Retired Post Whore
aboard the Argama
Are you saying taking off the stock turbos and installing an entire single setup is easier than changing cams?
This is not a good argument anyway. Cams are a good mod to do with either setup.
935motorsports
San Diego, CA
Anyone that thinks stock twins are better, has not DRIVEN a properly sized single setup.
It is much different then you think. Take a drive and trust me you will run, not walk, to pull those turbos off.
