Cheap Turbo on Ebay
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
"You Are Bidding the Following One
T3 T4 T04B Turbocharger
.60 A/R Compressor, 1.15A/R Turbine
3" Inlet & 2" Outlet"
As usual....a BIG@$$ Turbine A/R. :nono:
I won't doubt that it's a bad turbo...but I'd highly recommend having a professional tear down and inspect it before throwing it on your prized possession.
With the way people can get their hands on turbo's these days, I can't say that eBay turbo's are junk anymore (some of them still are)...but again, people don't understand the complexity of a turbo, therefore throw together great parts, but with cheap standards...
Good luck to you.
Buy it, blow it up, send it to us. I'll be waiting for a PM. ;);)
-Jeff
pearlwhite turbo
booost'nnnnnn
Oct 8, 2006
55
philadelphia
Good luck to you.
-Jeff
It's worth a try a few people i deal with have tried ebay turbos Xs power in specific, and have had good results. I am trying the T61. I'll let you know how it goes.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
well i was just browsing, im no where near buying a new turbo, im in the process of searching for a place to fix my supposed blown head gasket.:cry: the last thing on my mind is a new turbo:icon_conf
LordLo
242
OR
Go with something that has a longer warranty. I'd say buy the ebay xspower t61. It's actually just their t-70 compressor but with a smaller AR T4 exhaust housing (.84) on it.
I have one, haven't installed it yet, but looks to be a good turbo. No shaft play and spins pretty easily.
MKIIINA
Destroyer of Turbos
Plano, TX
you need to get a v-band flange and have it pressed and welded in. the warranty on those is a joke unless you open the box and its got something visually wrong with it its gonna be a pain to prove somethings toast.
g luck man
Selz202
More than Regular Member
May 1, 2005
248
Black Diamond Wa
Yep biggest problem with that is ".60 A/R Compressor, 1.15A/R Turbine 3" Inlet & 2" Outlet"
Spool up will take awile... and when it does it wont be much.
PowerTrip Performance
Custom Fabrication
Dec 5, 2005
209
Oregon
I've had several XS Power and SSAuto turbos pass through my shop, some of them are junk (by some I mean most) but on rare occasion I've seen some of them last and put down some impressive numbers. I myself have bought a few to use for mock up for manifolds and downpipes and kept one of the T61's
around. It seems to actually be a nice turbo. I can see that the center cartraige is a real Turbonetics, they ground the logo off, but didn't do a good job of it. I've ripped it all apart to inspect it...it looks as good as my Garrett (other than the compressor wheel looks like cheap china pot metal)
Heres some things to look at that I have seen wrong with them right out of the box.
1: We got one that the exhaust housing was JB welded together! It was obviously cracked during casting, they JB welded it and painted over it.
2: Had one right out of the box with a bent shaft
Honestly for the money if you are looking to do a low budget boost project you can't beat them. It beats the hell out of a used junk yard turbo (in most cases)
Hope that helps. I agree with the previous comment though...that particular turbo will takes days to spool, then when it finally does, the compressor combo is not enough to make it worth the wait.
LordLo
242
OR
I ordered a t61. The shaft wasn't bent and fins are good, no shaft play and it even comes pre-oiled. Not too shabby if you ask me.
drjonez
the motor city
www.4cefed.com
the biggest problem w/ebay turbos is that they are NEVER what they are advertised to be....i.e. they're not T61s or GT35Rs, etc. i'll let jon @ MDC pipe in as he's torn down many of them....
MRSUPRA
838
Maryland
1.15 turbine A/R. I guess since its a T3, it won't spool as bad as if it was a T4 with a 1.15 A/R. Still, it looks like it will be laggy without much top-end power.
I just don't understand why no one listen's.. The turbo and its sizing are going to effect More Than Anything how your engine is going to perform. In other words, spend the extra money on a turbo thats proven to perform reliablbly and sized right so you can get the most mid-range and high rpm power.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Thanks DR J.
Most of them aren't any where near what they say they are. The one you have pictured is most commonly advertised as a To4s or Tso4. Its no where near that.
Its actually a copy of a old John Deere to4b, with a small (~43lbs) compressor wheel with a P trim turbine on the back.
The housing is large enough a stock 7m won't spool it untill 4500-5000rpms.
Also, with most of the ebay turbos that I have torn down (all those comming out of China or India) they have all had walnut shells inside them.
Walnut shells you say?
They blast them with crushed shell after assembly to clean the outside housings.
drjonez
the motor city
www.4cefed.com
MRSUPRA said:
...I just don't understand why no one listen's.. The turbo and its sizing are going to effect More Than Anything how your engine is going to perform. In other words, spend the extra money on a turbo thats proven to perform reliablbly and sized right so you can get the most mid-range and high rpm power.
exactly!
the reason no one listens is because they're too cheap...:3d_frown:
LordLo
242
OR
ma70t said:
you need to get alot of custom parts to make that turbo a plug and play
Not at all. Just a spacer, v-band dp, and ebay manifold. That's about it, plus it helps if you know how to weld.
LordLo
242
OR
MDCmotorsports said:
Thanks DR J.
I don't know about walnut shells, but mine did have a few specks of some type of brownish cardboard like stuff. I took mine apart and cleaned it and crudely checked it for balance. :biglaugh:
ma70t
7mgte-s
Jun 7, 2005
141
va
like i said its not a plug and play turbo
