http://cgi.ebay.com/ebaymotors/T3-T...015QQitemZ250084741420QQrdZ1QQsspagenameZWDVW
whats wrong with this?
theKnifeArtist said:
Boost Lee said:"You Are Bidding the Following One
T3 T4 T04B Turbocharger
.60 A/R Compressor, 1.15A/R Turbine
3" Inlet & 2" Outlet"
As usual....a BIG@$$ Turbine A/R. :nono:
I won't doubt that it's a bad turbo...but I'd highly recommend having a professional tear down and inspect it before throwing it on your prized possession.
With the way people can get their hands on turbo's these days, I can't say that eBay turbo's are junk anymore (some of them still are)...but again, people don't understand the complexity of a turbo, therefore throw together great parts, but with cheap standards...
Good luck to you.
Buy it, blow it up, send it to us. I'll be waiting for a PM.
-Jeff
MRSUPRA said:...I just don't understand why no one listen's.. The turbo and its sizing are going to effect More Than Anything how your engine is going to perform. In other words, spend the extra money on a turbo thats proven to perform reliablbly and sized right so you can get the most mid-range and high rpm power.
ma70t said:you need to get alot of custom parts to make that turbo a plug and play
MDCmotorsports said:Thanks DR J.
Walnut shells you say?
They blast them with crushed shell after assembly to clean the outside housings.
LordLo said:Not at all. Just a spacer, v-band dp, and ebay manifold. That's about it, plus it helps if you know how to weld.
