Car won't start + one spare connector!
supramacist
1,501
The Grassy Knole
LOL..., did you switch your cam points to the upward position??
I'm glad you got that sorted out. I can't answer your question because I don't play with that. TDC is where it's at cat.
D
drumminforev
Guest
Ok, i fixed the timing, it was off for sure. now it cranks over real strong, still doesnt run.
the injectors will not fire ever.
i put gas right into the intake and it idles just fine for about 5 seconds. soon as it runs out, it dies.
SO, whats the deal????? ah help
jdub
Feb 10, 2006
10,730
Valley of the Sun
Post #27....4-27-07
johnathan1 said:
Have you checked for codes?
Again, Post #30....4-27-07
Again, Post #36....5-1-07
cuel said:
Again, Post #37....5-1-07
If you want help, you gotta help yourself...CHECK YOUR FRIGGING CODES!
You're spinning your wheels here man...you've had a couple pretty darn knowledgeable guys try to help you and you choose to ignore them. Watching a guy beat his head against a block wall is amusing at 1st, but gets old fast. Your choice on who you want to listen to.
D
drumminforev
Guest
oh thats my bad. i didnt see his link to how to check the codes. ill get on that next
oh and we'll see bout that ac, its got a compressor so looks good ha
jdub
Feb 10, 2006
10,730
Valley of the Sun
supramacist said:
So basically...., another 900 posts give or take and I can have a supramania
official expert under my screen name???:naughty:
Why don't you take that up with SupraCentral...I'm sure he will get right on it ;)
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
I didnt feel like reading through everything, but if your injectors wont fire, go from their.
Is thier power to them? Is the wiring good? Filter New? Pump working? Lines clear? Check your fuel system.
If you have power to the injectors, then you have a fuel problem ( I think, may not be that simple). If you pull your line off and put your key in, turn it, and it sprays fuel everywhere, you have a electronic problem :biglaugh:
D
drumminforev
Guest
Ive done all that. its purely injectors wont fire. fuel, spark and timing are good. thanks for telling my i have an electronic problem, now i know exactly where to start.
im gonna run the codes test in a min
