Amps or Volts?Agallington;2021868 said:Not saying it couldn't be the starter, but it is pretty new. It has no problem starting when the engine is cool or cooler. When this happens, my turbo timer, which displays battery voltage shows 10-11 amps only. Connected right after the ignition. It will a
Most always eventually start, but sometimes it takes a while. Could this be a starter relay problem even though it is only when warm(as far as I can tell so far), or ignition, or?...
gsxr141;2022005 said:but tapping the starter = mechanical failure and not an electrical problem.
jetjock;2022024 said:Correction by tapping indicates worn brushes and/or worn solenoid contacts, both of which can be replaced. And while they can be at fault for the problem talked about in this thread they seldom are.
gsxr141;2022005 said:i'm on my 3rd aftermarket starter in a year.
hvyman;2022040 said:Aftermarket starters and alternators are complete junk now a days.
agallington;2021992 said:did the relay and it is now hacked.
gsxr141;2022108 said:whatever is causing the problem, this fucking bosh starter i bought is worse than the cheap autozone one i had before. it almost left me stranded 3 times today. wtf!!!
