Not missed. If you're sure the problem is the wire. If, however, the root of the problem is the ignition switch, it's going to get worse, and you still haven't solved it, because you haven't fixed the actual problem. Maybe in your case, the wire is broken, and replacing it fixes the problem. Hooray. But it's not going to be the case for most people, as wire is a relatively low incidence failure part, and when it DOES fail, it's generally right at the connector, and is reasonably obvious. Relays are also relatively low incidence failure parts, but it does happen. Even if it is $30, I'd rather not spend it, or the time installing it if it doesn't address the cause of the failure, and I'm back diagnosing the problem when I'm late for work and it's dark out.
60-90 minutes for the mod as listed is probably reasonable. Possibly doable if you're replacing the wire from the solenoid contact to the wire trunk as well. The point though is that it's not a guaranteed fix, because there's still other things that it could be. Maybe it makes the symptoms go away for a while, and they come back when I go to start the car next Spring, because now the stock relay is really fried. Or the ignition switch isn't making any contact at all now, or a completely different piece of wire somewhere has finally completely let go. In that case, I'm out the $30 and the hour to an hour and a half (During which time I could have properly diagnosed the problem, and at least known what the correct solution is.)
Done right, there's no guess work. I don't have to wonder if the problem will come back. I don't have to remind myself that the TEWD is no longer correct on that page for my car. I know that I had a specific problem with the car, and that I fixed it.
