car bucks when turbo spools
supraian
66
san diego
once the turbo starts to spool a little (10 inhg vacuum) the car hicups a little. i've checked for boost leaks but have found nothing. vacuum at idle is good at 20 in hg. what else could be doing this?
robbo185
693
Chicago
timing, boost leak, fuel pump could be a number of things
build a boost leak tester and start there
also check the codes that would help diagnose the problem better
supraman16
SUPRASAVER
Jul 23, 2006
68
Atlanta
drive the car shift in to 3rd around 2500 rpm then floor it check boost gauge
see if it holds. IF it drops you have a boost leak. if it doesn't your running
too rich. do you have any mods?
supraian
66
san diego
code 34: Turbocharger Pressure
Diagnosis
The turbocharger pressure is abnormal.
Trouble Area
Turbocharger
Air flow meter
ECU
Intercooler system
not fuel cut though, it starts before i even start boosting. i remember bottoming out preety hard a few days ago, i'm gonna check the i/c for damage but even then wouldn't my vacuum be off?
supraian
66
san diego
can't find any leaks. once its at full boost its steady and does not drop. its popping a little on idle now. changed out the afm, same problems.
souprat
fairfax VA
does it throw a CEL when it does it? really sounds like a boost leak to me to. they can be a real pain in the ass to find sometimes.
supraian
66
san diego
no codes when it does it. i'll check the accordion hose next time i have a chance i'm in the middle of moving. i do remember it having a small crack, maybe it got bigger. i'm hoping thats all it is.
robbo185
693
Chicago
supraman11203 said:
my car bucks tttttttttttooooooooo i dont know want wrong can you guys help an tell me whats the problem. i wonder if it is the turbo seals....
if it was turbo seals you would see blue smoke while driving/boosting
