Cant tell if my mk3 was originaly turbo or none...HELP
Koenigturbo
1,338
Oxnard CA
deabionni:
Hey since you sell insurance, let's do a S.M group buy for our Supra's, Just make sure we get a really good deal,........:rofl::rofl:
Turbo Habanero
4,229
Tucson,AZ
--Wolf--;1421795 said:
Will have to double check, but am pretty sure my VIN is MA70 and is factory turbo. Might be because it's a JDM 86.5 (yes they came out factory 7mgte in 86)
I thought Turbo model didnt come until 87
And there is NO MA70 VIN that is a Factory turbo only Chassis Code witch is what you will on the firewall look at the door for the VIN if it is a orig. turbo model it will be MA71.
Jeff Lange
Administrator
4,919
Sunnyvale, CA
jefflange.ca
That is correct. What Japan uses for a VIN is the chassis number, which is MA70 for all 7M-equipped Supras.
Interesting side note: Japan never had 7M-GE's in their Supra, so all JDM MA70's are Turbo.
It didn't, in Canada/USA, however in Japan there was no N/A model. The turbo model was introduced from the get go.
Like I said, the VIN in Japan is the chassis number, which means the VIN for a Japanese Supra with a 7M-GTE will be MA70-0000000.
When people talk of MA70 or MA71 in the VIN, they are ONLY referring to North American 17-digit VIN's. Even other countries with 17-digit VIN's WILL BE DIFFERENT.
Jeff
--Wolf--
104
Chch, New Zealand
Don't worry Habanero, most people here will try and argue when I tell them I have a FACTORY 86.5 7mgte. US/Canadian cars aren't the only ones in the world :)
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
I think even the MKIIs have some 5 or 6Ms with turbos or was that few and far between?
Though non made it factory in US.
Nghty89
Zombie Chicks Are Hot
Mar 26, 2008
978
7 Cities, VA
Jeff Lange;1421784 said:
MA70 = Turbo and non-turbo Chassis Code
VIN is not chassis code. In the VIN, MA70 = N/A, MA71 = Turbo.
No, Toyota never ran out of MA71's and used MA70's or any other far-fetched idea.
Jeff
Ok, I figured I was insane. :naughty: I have no idea where I read that and got that idea... :nono:
Not to thread jack, but why did they switch between MA70 and MA71 chassis for the turbo and non-tubro's? Why not keep them the same as the VIN, strictly MA71-turbo and MA70-n/a? Not that I'd expect anyone to know what Toyota was thinking, just curious. :icon_bigg
rayall01
901
Westfield, ma
They did it to fuck with you, they knew you would be asking.:biglaugh:
Jeff Lange
Administrator
4,919
Sunnyvale, CA
jefflange.ca
They did it because it's the way Toyota does chassis codes. If there was an MA71, it would either have to have a major chassis difference (AWD vs RWD, etc), or have a different engine block (6M vs 7M).
It's like how MR2's with a 3A block are AW10's, and MR2's with a 4A block are AW11's. It doesn't matter if it has a 4A-GE or 4A-GZE, 4A is 4A.
I could go on and on, but I won't. The point is, all A7x series Supras with a 7M are MA70's, turbo or non.
Jeff
sk6471
Quietly Lurking
May 28, 2005
91
Texas
Jeff Lange;1422293 said:
The A60 series had the M-TE (2.0L Turbo Inline-6 SOHC 8-valve) for 6-cylinder turbo power.
Jeff
Wouldn't that be 12 valve. (Please don't ban me.;))
