i have fought with removing this damn tractor wheel from the axle. three slid off easily but the fourth is jammed. on the other axle, there is a key (?), a little square piece of metal that slides into grooves in the tire and axle, locking the two togther. is my problem in here, or is there any way to take this out and then remove the tire?
i've finally had to take the transmission out of the tractor so i can separate the axle from the differential, and my problem still isnt going anywhere. ive pounded and beat and pulled and used pb blaster, wd40 and all other lubes i can find. even heated the wheel for a while trying to remove this. pics are on the way soon
any ideas?
any ideas?
